Took a few days off to do some spring cleaning around the house.
Remade the upper half of the canopy hinge D02-11. The drawing length is 28" but with changes in the length of the glareshield, this length needed to be increased to 29". The canopy side tube D02-07 will need to be refit to the new piece.
I think I will be able to reuse the side tube even though it is about 1" short of an ideal length. The D02-08 canopy corners have sufficient length to adjust the fore/aft position of the canopy bows.
Started on the pattern for the forward canopy bow.
Spent some time adding a missing "Ident" push button to a used King K76TSO transponder that I recently purchased.
